1988 force 50 hp, how much fuel pump pressure should you have at the carb????????
M mort kent Seaman Apprentice Joined Aug 5, 2009 Messages 34 Sep 5, 2009 #1 1988 force 50 hp, how much fuel pump pressure should you have at the carb????????
F foodfisher Captain Joined Feb 18, 2009 Messages 3,756 Sep 5, 2009 #2 Re: fuel pump pressure I don't think you're fuel injected. The fuel pump just keeps the bowl full. Vacuum from the pistons suck the fuel out. Or am I missreading your ?.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,913 Sep 5, 2009 #3 Re: fuel pump pressure I've never seen a spec on it, nor measured it. Should just be a steady stream, 2-3 lb of pressure, so as not to blow past the needle valve.
M mort kent Seaman Apprentice Joined Aug 5, 2009 Messages 34 Sep 5, 2009 #4 Re: fuel pump pressure thanks much, steady stream I don,t have. mort
