VisionIsle
- Feb 10, 2006
- 98
Re: Fuel Pump Obsolete
The reason I pulled the distr. was that it appeared to be slightly past the #1 on the cap and the previous chain had a 1" play in it. I suppose I was thinking that possibly it could have been off a tooth from the play?
Anyways, what happened was the boat would accelerate and decelerate inconsistantly as if gas was being supplied erratically, I found a bent tab on the 2 piece eccentric and replaced it. At the same time I noticed the chain was loose and replaced the timing set. Its a 351W 1977 Ford ( Volvo Penta AQ240 ). I replaced it with # 7811 Edelbrock. Its made for a Late Small Block Ford (not sure how late they mean) .
All I know is that I went out with a fuel issue and after messing with the timing
I can only get her to idle for a few seconds before it wants to die.
