fuel pump - gasket needed?
bomber88
I'm comparing using fuel pump 438556 (2 tubes) or 438559 (3 tubes). I know 438556 mounts to the block and uses the pulse in the back which requires the use of a gasket to seal it. 438559 has an external pulse nipple and can generally be mounted anywhere. So why are folks selling 438559 with a gasket?
http://www.ebay.com/itm/New-Johnson...OMC-/260746052203?hash=item3cb5ad026b&vxp=mtr
This is making me second guess that I know how these things work.
FYI - I'm replacing a VRO pump with busted casing (fuel leak) on a 1988 110 V4 evinrude.
Both pumps work exactly the same way.--------They use a positve pressure pulse and a slight negative pulse to move the fuel.------On 556 the pulses reach a chamber via a hole in the back.-----On 559 the pulse reaches the same chamber via the hose and passage way in the pump.
bomber88
I understand that. But look at the picture of the back of 559 in the link above. Is that hole plugged internally somehow such that that pulse only enters through the nipple? I didn't expect that hole to be there on the 559...only on the 556...and the fact that this seller is including a gasket makes me think maybe that hole has to be sealed the same was as the 556. That make sense?
emdsapmgr
The factory may have decided to use the same casting for that back plate, just adjusting the innards for the specific application. That reduces a need to just one part number and reduces assembly complexity. A guess.
bomber88
As many people as it seems have used this 559 pump for VRO replacement, I would assume someone one have documented it as an issue by now. I went ahead and ordered one. If that middle hole on the back needs to be plugged, I'll let everyone know.
