I'm comparing using fuel pump 438556 (2 tubes) or 438559 (3 tubes). I know 438556 mounts to the block and uses the pulse in the back which requires the use of a gasket to seal it. 438559 has an external pulse nipple and can generally be mounted anywhere. So why are folks selling 438559 with a gasket?
http://www.ebay.com/itm/New-Johnson...OMC-/260746052203?hash=item3cb5ad026b&vxp=mtr
This is making me second guess that I know how these things work.
FYI - I'm replacing a VRO pump with busted casing (fuel leak) on a 1988 110 V4 evinrude.
