Fuel pump fitting on V8-430-CE-M Engine
nrhansen
Could someone tell me if the fitting I have circled in this diagram is a water cooling fitting?
Fun Times
Yes...See hose number 27, https://www.volvopenta.com/shop/0/part-sections/54165087
In the first minute he goes over the pump fittings for you,
Donald0039
You pull that hose to winterize but at the other end of the hose. Not the fuel pump end. Pull the hose down and drain.
