Fuel Problem on my 1996 225hp ocean runner
Lio_miami
Hi guys got a tough one my engine its running out of fuel after like a minute of stopping squeezing the bulb it jut slowly dies... when i remove the big bolt on the carbs there is no fuel i already replace the filters fuel line and the tank has no valve in it.. and today just put another fuel pump with the same results i am going crazy any ideas will be highly appreciated.....:confused::confused::confused::confused:
clanton
Re: Fuel Problem on my 1996 225hp ocean runner
What kind of pump?
boobie
What's the big bolt on the carbs ??
Faztbullet
Either the air motor is bad on VRO or crankcase pressue is low due to worn cylinder and piston skirt. Common problem on older models...
Lio_miami
asdas.JPG these are bolts i was talking about.. i know the carbs are not getting fuel other than the one i squizz the bulb
fishman204
first try a remote tank and see what happens.Then check fuel line from the main tank and the vent line.On the vent can you blow back into the tank.Sounds like a blockage to me.
Chris1956
Honorary Supreme Mariner
You might check the vapor pump as well.
Lio_miami
I am gonna try a remote tank today...where is these vapor pump At..
boobie
Pull the fuel lines off of the carbs, pump the primer bulb and see if you get fuel out of the lines. No fuel, problem in system. Fuel, problem in carbs.
bob johnson
do you smell gas?
i had a similar thing happening and id have to squeeze the primer bulb 5 times to get out of the harbor.....the big hose that went to the PULSE valve under the fuel component bracket was cracked....I didnt find it until I decided to replace the fuel pump.... i replaced the pump anyway and fixed the hose....but I suspected the fuel pump was still good....
so it was either the fuel pump or the hose on my problem
if you have an air leak you could be losing prime
since your motor starts, then dies, i wouldnt suspect a stuck float in the carb
good luck
bob
bob johnson
No i dont smell or see gas coming out
id start looking at all your fuel line connections... you might be losing prime,(because of an air leak) or you have a bad fuel pump.... you are running your motor on the initial prime when squeezing the bulb, but once the carbs run out of that fuel the motor dies.....no more gas is flowing to the carbs..
you could hook up a temporary auxilary gas tank and plumb it direct to the motor...( making sure all the connections from the cowling entry to the fuel component bracket are good...
if it still happens you have narrowed it down to the fuel pump or the fuel component bracket assembly some how...it takes time and patience to solve these issues sometimes
bob
bob
Put a cheap pressure gauge on the fuel pump pulse line --crank motor and observe the gauge.-------There could be issues with crankcase pressure pulses.
Lio_miami
I crank the engine with pulse hose disconnect and i feel presure comming out and some vacum too still need to get a gauge
Lio_miami
At these point i am ready to buy a new fuel pump.. Which one will be my best choise? i dont the vro side on mine always pre mix mu fuel..
It is quite simple to take the VRO pump apart and inspect it.---That might be the cheapest repair.
