Fuel Problem Gone....
FreeBeeTony
Went out tonight..........went from idle to WOT @ 4600 RPM (not too calm and 2 people on board) w/o any problems...........added dry gas, replaced fuel filter and tried Don's geezer trick.............seems nice and strong.
I love the way it sounds at WOT!!!!!!!........only leave it there for a matter of maybe 30 seconds.
I also retarded the timing to ~ 6*BTDC........is this OK?
Re: Fuel Problem Gone....
Ayuh,....... Great,.!..! :)
Why'd you cut the Timing back,..??
FreeBeeTony
Thought the timing had something to do with the problems at WOT........seemed like it was at 8-10* BTDC..........is that too hot or should I bring it back there?
Don S
Put it back where it should be. That is what the advance curve is based on.
And what's this geezer trick I gave you????
FreeBeeTony
geezer trick: "rev the engine to 3-4K RPM, close the choke and let the engine suck the crap out of the carb".........that's my version...........seemed to work.
Don S
LOL, yea, now I remember. Works, don't it. I like your version. Not near as much typing.
FreeBeeTony
yup, the geezer trick seemed to work along with changing the filter and adding dry gas...........any harm in leaving the timing where it is?.......really sounded good at WOT...........if I can still hit 4800 by myself, should I just leave it?
FreeBeeTony
Re-checked the timing..........fluctuates between 6-8*........decided to leave it alone.
Went fishing today with wife......engine ran flawlessly.........even caught a 23" fluke!!!
