Fuel prime problem 1997 Evinrude EB225SLEUD
dcanelon
Dear friends I only hope someone can give me a hand. Yesterday, my outboard (OB) died everytime I tried to rev (rpm) it up. Today, I discovered that priming it continously, from the switch or from the primer motor, while moving forward the control handle, made it rev up and run nice up to 5000rpm; however, after going into idle, the OB tends to die. It starts nicely, but after a minute or two, dies. It is a pain to manouver at the dock, because it dies, or moves very slowly, just after moving the control forward or backwards. As I said before, in the open sea, the continous priming just after moving the control handle forward, makes it rev up strong and even.
I know that this problem could be several things, like: 1) Little air in one of the hoses that affect idle, but not when reved up?. Darn, I have checked these hoses a million times. 2) Could it be that the pulses from the engine into the fuel pump are not strong enough at idle?, or a faulty pulse limiter?, do these go bad?. 3) Carburators adjustment?, when at idle, the OB runs even and quiet. 4) Timing?, I dont have a light so I havent been able to check this; however when the OB revs up, it runs nice, so I?ll forget about timing for now, as I?ll forget about the fuel pump because if it runs good after reved up, the pump should be ok, ah?; incidently I did change the fuel pump kit (exhiguy), just as a precautionary measure because after 19 years, .....?!.
Conclusion: priming problem at idle speed and during the process of reving (rpm) up.
I need someone to please tell me if I am in the right direction, and if possible, an idea or two to solve this problem.
Regards friends,
Douglas C.
PS this engine is 19 years old, 16 of them stored. It has only a 100 hours, it?s brand new, and everyone tells me to keep it because this Evinrude model is one of the best, a real fighter. Sorry for the long post, but I wanted to share some of what I have learned from the books.
flyingscott
If it sat for that long I would go through the carbs clean them good with good kits. Check all hoses and the small ones should not effect idle I believe they are primer llines only. Double check the work on the fuel pump. And how old ids the gas and is the VRO Hooked up?
dcanelon
Hello Flyingscott: thank you for your response, ....what haven't I done...!, before I attempted to start the motor after a decade and a half stored, I disassembled and cleaned carbs, changed fuel pump kit and have rechecked it twice since thinking the pump is to blame, changed the impeller and all the rubber parts, cleaned the gas tanks (stainless steel) with ultra sound, changed all the fuel hoses coming from the 2 tanks to a new a racor filter, new hose to the motor, the VRO oil tank was brittle so I discarded it, for the moment I plugged the oil port at the fuel pump, disconnected the low oil alarm, and am using premixed gas, changed thermostats (temperature is fine, 140 deg), installed two new temperature probes, one for each head with new temp gauge with a two pole switch to check them both, checked all of the alarms, installed a new sound alarm. changed spark plugs. I did not change the carburator kits, 'cause when I had them disassembled I did not see a need to change anything, all looked so new, but..., please tell me about these kits. It surprises me that after priming the motor repeatedly during take off, it runs nice, 5000 rpm, 45 mph during tests, its a 19' sport boat perfect for skying in the coral reefs where we hang out.
Tell me something commander, priming is only for starting, right?, once the motor starts the fuel pump takes over receiving the pulses from the engine, am I stuck thinking the problem is there?, because the only other ?? possibility would be air in the system, but then.., how come it runs nice once it has picked up revs?, air in the system would cause it to fail at all regimes, right?.
Well my friend, lets leave it here for now, I am going back to the beach this saturday, and I guess I'll have to recheck the hoses and take a look at the carburators, and runs tests in the open sea with the primer, to see if I can detect anything in there. If you can think of anything, let me know.
Sincerely,
Douglas C
levittownnick
Hi Douglas,
There is a major difference between Primer & Choke. The primer, usually a squeeze bulb with a check valve sucks fuel from the fuel tank and sends it to the carburetors. When the carburetors are filled the primer bulb gets hard because the float valve in the carburetors stops the fuel flow. The Choke, usually operated by the ignition key, increases the fuel to air ratio to compensate for the denser air at cooler temperatures. If used excessively, it causes a condition known as "Flooding" which causes the spark plugs to foul causing a lack of spark and/or "Missing" & hard starting. I think that it is a good plan to figure out which of the 2 conditions are faulty. If the fuel pump is not supplying enough fuel, which can be determined by having an assistant pumping the Primer Bulb as the boat is trying to be accelerated. If the engine runs well during that procedure, the next step is to determine the cause of the inadequate delivery. (Easier said than done.) Good luck,
Nick
levittownnick
Hi Douglas,
​Nick
flyingscott
Hi Douglas,
​Nick
There is no choke on his motor only the electric primer. Having to use the primer to get it to rev up indicates a lack of fuel to the motor. Do what he said with the fuel line bulb.
Faztbullet
You said you cleaned carbs but did you install new kits when reassembled???? Not using new gaskets can cause air leaks,and only use OEM kits.
dcanelon
Hi: first, I'd like to remind you guys that the problem with my motor is that it dies when accelerated from idle up. The primer bulb test was done with no result, the revs did not go up. Only choking it with the ignition key will make it rev up nicely: however, when brought down to 1000 rpms, it dies. This week I shall adjust the idle, clean the electric primer filter, although I know these will not solve anything.
Please, let me know what you think of the result of the primer bulb test, and other suggestions you may have.
Sincerely,
Douglas
ondarvr
I think you should start looking at the carbs again, you still have a fuel delivery problem.
jakedaawg
Clean the "off idle" or "transition" circuit in the carbs. These are the four very small holes that enter the throat of the carb as the butterfly moves over them. They work as both air bleeds and fuel meters depending on the position of the butterfly. I belive to properly access the system removal of the welch plug is necesary
Fed
Once you accept that the key operated primer is a valve & not a pump you will understand why everyone is telling you to look at the carbs.
dcanelon
Hi guys. Jakedaawg, I overlook these orifices when I cleaned these carbs, and what you suggest sounds pretty much like a solution to my problem. I'll get into that next weekend. However, I have a question: ?can these particular (Evinrude) welch plugs be removed without damaging them?, or if a make a hole in them, could I fix them with say...., epoxy?, the thing is that I don't think I can find these plugs here in the country where I am right now.
One curious aspect of this, I went into the iboats.com page, and in the diagram of this carburetorI I could not find a welch plug, do they have another name for it?
Thanks again,
Douglas
interalian
No, the welch plug can't be re-used. I doubt any epoxy would hold up to repair one either. The plugs always come with the full OE carb kits though.
jakedaawg
Thanks again,
Douglas
Sorry, I was thinking a different carb. On your motor you will need to pull and clean the throttle bodies and then do a link and synch as per manual.
dcanelon
Thanks Jakedaawg for your advice, and thanks to the other friends that have gotten involved in this post. Of course I can't call victory yet, but I feel I am close. I'll let you know the result.
Regards,
Douglas
