Dear friends I only hope someone can give me a hand. Yesterday, my outboard (OB) died everytime I tried to rev (rpm) it up. Today, I discovered that priming it continously, from the switch or from the primer motor, while moving forward the control handle, made it rev up and run nice up to 5000rpm; however, after going into idle, the OB tends to die. It starts nicely, but after a minute or two, dies. It is a pain to manouver at the dock, because it dies, or moves very slowly, just after moving the control forward or backwards. As I said before, in the open sea, the continous priming just after moving the control handle forward, makes it rev up strong and even.
I know that this problem could be several things, like: 1) Little air in one of the hoses that affect idle, but not when reved up?. Darn, I have checked these hoses a million times. 2) Could it be that the pulses from the engine into the fuel pump are not strong enough at idle?, or a faulty pulse limiter?, do these go bad?. 3) Carburators adjustment?, when at idle, the OB runs even and quiet. 4) Timing?, I dont have a light so I havent been able to check this; however when the OB revs up, it runs nice, so I?ll forget about timing for now, as I?ll forget about the fuel pump because if it runs good after reved up, the pump should be ok, ah?; incidently I did change the fuel pump kit (exhiguy), just as a precautionary measure because after 19 years, .....?!.
Conclusion: priming problem at idle speed and during the process of reving (rpm) up.
I need someone to please tell me if I am in the right direction, and if possible, an idea or two to solve this problem.
Regards friends,
Douglas C.
PS this engine is 19 years old, 16 of them stored. It has only a 100 hours, it?s brand new, and everyone tells me to keep it because this Evinrude model is one of the best, a real fighter. Sorry for the long post, but I wanted to share some of what I have learned from the books.
Regards friends,
Douglas C.
