Re: fuel or ignition problem
Your 1979 ignition system uses two packs. That can be helpful when troubleshooting ignition problems-which you are currently doing. It should be as reliable as the newer ignition systems. Your pack part number indictes it is an unlimited power pack-most today will limit rpm's to 5800. Unless you locate an old pack of this same part number, most replacements will be rpm limiting at 5800. I'd recheck your compression numbers with another gauge. They are extremely high for an OMC V6. Usually compression is in the 95-100 lb range unless it has high compression heads-then it will be slightly higher.
