Lubosleftboot
- Feb 26, 2006
- 208
Noticed today that there is a hairline crack on the crankcase upper on this motor as there was a small amount of water coming out of the fissure whilst the engine was running.
I noticed also that one of the vacuum pipes that connects to the carb is very close to where the crack is situated as per this pic
My question is could this fissure be the cause of bad induction / fuelling ? I have put on a temp repair of epoxy and will have another go at this motor once the epoxy has cured and if it now runs properly I will get the fissure ali welded by a pro..just dont want to go to the bother of doing this if this is not the problem.
LLB
LLB
