Fuel line thread size
Btonty
Losing my mind here. 92 4.3 lx motor with 4 barrel carb. My sob story is i got a boat told was ready for the water....free! So after a new reman engine, ignition, outdrive rebuild, and everything else mechanical you can name, I just finished rebuilding the carb. Issue I have is that I snapped the fuel pump to carb line as the line was frozen in the b nut.
New line coming next week, in the interim I'm trying to hook up a flex line just to run the engine. However I can not for the life of me figure out the thread size to get fittings. Tried 3/8 flare and NPT. NPT is clearly way off. Flare is also NFG. Anyone know the thread size and fittings off the carb fitting (has a 4 bbl 9600s carb with a brass fitting there) and off the fuel pump fitting (same as the carb fitting).
Not looking for a permanent fix just to get the thing fuel to run to make sure all is good until I get the factory metal line next week.
Thanks
Brian
Btonty
Thank you! Spent some time overnight researching further it is inverted flare, at Advance Auto picking up fittings at the moment.
