Fuel leak
clearbluewater
Greetings
I went to water test my boat first time this year and I noticed a fuel leak from area highlighted in picture. Looks like the carburetor. I think it's coming from the seams.
Engine started ok and also ran but i turned off once I noticed leak.
its a $1 gasket (a pack of 6 bowl and metering block gaskets for like $10)
suggest you pull the carb off and determine is it the metering block gasket or the bowl gasket.
clearbluewater
Thanks. Is there a way to find out the carburetor model so I can buy the correct metering block gasket and bowl gasket? I have a 3.0 GLP-E
clearbluewater
Thanks! Is it simply just popping it out undoing the 4 bolts?
If you can share a how to video or link that will be great.
Now is where you go out and google how to dissassemble a holley 4150 and go thru it, and not the wrong stuff in you tube. Go to Holleys web site and look for yourself. Additionally Jeff Smith has articles on it
