fuel hose
cls
Can someone tell me what fuel hose i sould use .I have a 17 foot 74 baylinner with a 140 mercruser.The fuel hose from the tank to carb is 37 years old i think i sould replace it .Would it be 3/8,5/8 or 1/2inch id i have not removed the old hose yet and what marine grade should i use thank you
gatorfan6908
Re: fuel hose
Good morning cls! You should be able to look on the side of the hose for the size, 3/8, 5/8, etc.. Or you could remove a small piece and take it to the parts house and let them size it up with one of the connectors. Either way, it is a GREAT idea to replace it, especially since it is 37 years old!!!! As far as marine grade fuel lines.... I would leave it up to one of the experts here in the forums. I'm sure they will chime in anytime and give you the answer you are looking for. Best of luck to you!
Lonnie
robert graham
Re: fuel hose
Take a sample section of your old hose to the boat dealer and buy sufficient length of "Marine Fuel Hose"....not a good idea to use the "Automotive Fuel Hose" like from Autozone, Advanced Auto, etc. The "Marine" hose will cost you a good bit more, but worth it in performance and durability. Probably a good time to replace all the hose clamps also. I'd say after 37 years you really got your money's worth out of those old hoses!;)
Georgesalmon
Re: fuel hose
Marine hose is more fire resistant than auto hose for one thing. You should use Coast Guard approved marine fuel hose. I'll bet that it is 3/8".
oops!
Re: fuel hose
its a 3/8th hose with a green stripe on it....
if you have a local hose suppl;ier, they wuill carry marine grade hoses...
or you can order it here at iboats.
Re: fuel hose
it seems to me that an I/O had a particular type of fuel line. I think it was marine fuel line type A. However, it is best if you verify that ...
Yacht Dr.
Re: fuel hose
I would think Gates green stripe fuel hose is good enough.
What is the diff between this auto fuel hose and Marine grade hose ?
Works for fuel injection on cars and high pressure right ? much more rated then simple carb fuel lines.
Just wondering out loud..
YD.
cls
Re: fuel hose
I think the Gates Green stripe fuel hose would be plenty good.I to would like to know the difference between Gates and type ai iso7840 marine grade
robert graham
Re: fuel hose
YD.
I don't know what the differences are, but based on all I've heard and read, I'd stick with the "Marine" specified....Maybe it's something to do with the damp marine environment, UV exposure, marine fuel additives?....Maybe there's an expert here who knows?
Re: fuel hose
YD.
Ayuh,.... The difference is Coast Guard Approval...
Marine fuel line will say so, right on it...
Yacht Dr.
Re: fuel hose
Okies I get it now.
Gates does have Marine grade hose. Both types in fact.
I guess the shielding inside the hose is different.
YD.[FONT=Arial, Helvetica, Verdana][SIZE=+1][/SIZE][/FONT]
cls
Re: fuel hose
I just want to thank all of you for your repleys. I will use marine grade 3/8 AI -ISO7840 .The old hose had this weired type outer coating no numbures or anything to go by thanks again guys this fourm rocks.
Yacht Dr.
Re: fuel hose
Thanks for coming by :) stick around mate :) .
YD.
PS. showing an appreciation is very well received for us :) .. some should take note of your comment.
