fuel guage????
iconracing
i have a 1988 celebrity 4.3 mercruiser and the fuel guage always reads 3/4 is there a universal sending unit i can get?? or is the guage off some how?
HT32BSX115
Re: fuel guage????
Howdy
You either have a gage problem, a sender problem or a wiring problem
All are repairable or replaceable
You will need troubleshoot to determine
dgirt
Re: fuel guage????
I picked one up at Damark Marine in Gibraltar for my tank. I think it was 24.00. Universal, cut to fit dimensions of tank. In the case of yours, I suggest removing it from the tank and working the float arm all the way up. If your gauge reads full that would eliminate the wiring and gauge. Then you just have to find out if the float doesn't go to the top as installed in the tank. May be saturated causing it to suspend below top. Could have an obstruction preventing it from reaching the top.
Replacement in mine reads WAY past full now when full. I am only on my first tank of fuel after the change so I am am still trying to figure out what the readings REALLY mean.
Re: fuel guage????
Do a search for fuel gauge problems. There are well over 50 of these on this forum. The biggest share of them have a diagram and troubleshooting info.
