Fuel Gauge Stopped Working on my Boat
Luckylee
I have two fuel tanks and one fuel gauge. I had a short that melted my ground wire to the fuel gauge. I have replaced the fuel gauge and a new switch that controls the two fuel tanks, but the fuel gauge will not work. Do I need to the ground wire to the two fuel tanks? What do you think I need to do to fix the problem? Now can I test the ground wire? I am stuck at this point.
The fuel tank should never have a hot wire anywhere near it
A green bonding wire, a black ground wire, and a pink signal wire to the gauge ( variable ground)
I would look to see what short melted the wire and fix the issue
mike_i
Do you know what caused the short and have you fixed it?
