I have a 96 CrownLine 5.7LX EFI Mercrusier, Bravo One, engine Serial # OF795033. The motor starts fine and idles good when I start to give it throttle it starts to go then the injectors shut down, but it will run at full throttle, anything in between will die, I cleaned the check valve on top of the fuel tank replaced the fuel line fron the tank to the diaphram fuel pump, changed the fuel filter. When I disconnect the fuel line from the diaphram pump there is hardly any fuel in the line from the tank, does this mean I have a bad diaphram pump? Any Help would be GREAT..
Thanks
Rod
Thanks
Rod
