FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
If you are going to store it for more than 3 months, you probably should drain the vapor seperator as it holds fuel that can go bad. Other wise be sure to add a fuel stabilizer to the fuel and run the engine for 10-15 minutes to distrubite it.
The owners manual says to put the drain hose outside the cowling, loosen the screw, tilt the engine up and to the starboard side, watch for fuel to start flowing, then lower the engine to allow siphon to finish the draining of fuel then close the screw up tight and reclip the drain hose.
I usually pull that stuff out and off motor in fall and replace so in the spring we're ready to go. But I do keep an eye on it during the season and change out when necessary.
