Brandon12345
Thread starter- Joined
- Jun 12, 2011
- 29
I have a previous long post about my ongoing problems here: http://forums.iboats.com/showthread.php?t=489547
To sum up, I have cleaned the carbs twice and replaced the starter. I previously had a problem with the engine cutting out and dying when i shifted into gear occasionally and then when i put it into WOT.
After replacing the starter and cleaning the carbs, I was able to get it started with the fast idle lever up, but when i put it down, the engine would die. After trying to make adjustments to the idle screw, the engine won't even start unless i spray fuel direct into the carbs, but dies moments after it starts. The 2nd time I cleaned the carbs, I adjusted the carb floats to about 1" below the carb as according to the service manual instructions (which say 7/8"-1 1/8" below level).
I am at a bit of a loss right now and have no clue what to do next. My thought is that it is definately a fuel delivery issue since i can spray fuel direct and the engine will at least start momentarily. Any suggestions or thoughts on what might be wrong or what I should do next? I really don't want to pay someone an outrageous sum to look at it, but I feel like I am about out of options. Thanks in advance for any suggestions.
