sms986
- Sep 18, 2017
- 334
So a few months back, I purchased a 1989 Larson DC215 with a mercruiser 305. The block was cracked, so I picked up a 350 short block, changed rings and bearings, and put all of the 305 gear back on it. The tank was full when I purchased it, and I'd estimate the fuel in the tank to be about two to three months old. So I rebuilt this engine, put it in the boat, aligned it and serviced the outdrive/bellows while it was apart. I "rebuilt" the qjet, replacing gaskets and the account pump/check ball only, cleaning the carburetor out vigorously while apart. First start with the new engine in place turned over and fired up instantly. That entire evening I ran the engine for about a half hour, intermittently, setting timing, breaking in cam and lifters, etc. Started fine each time. Had to leave for business and didn't return until 5 weeks later. First thing I did when I got home was try to start it. It would not fire. Accelerator pump didn't squirt anything into the intake tract. Finely poured some gas down the throat and got it to fire. However, I had to repeat this process and fiddle with it all afternoon to run it. Tore the carb apart and found the new accelerator pump had a torn plunger. Replaced the pump and cleaned the fuel line all the way to the tank. While the carb was off I turned it over and got a healthy kick of fuel from the fuel pump. So I got it together and test fired it a few times no problem. Took it out the day after and it started fine. Let it warm up at the dock for 5 minutes, ran at various throttle positions for about 15 more minutes, then shut it off to fish for a bit. Started it up 20 minutes later to go to a different spot. Started fine. Ran for another 20 minutes and when I went to position myself, I shifted to reverse, stopped the boat from drifting forward, and shifted to forward to turn the boat slightly. When I shifted to forward the engine died and wouldn't start up. Went back to check the carb for fuel, and the accelerator pump pushed out no squirts of fuel, just a few puffs of vapor. Pulled the fuel filter off and it was still full. Couldn't get it to start. Put some fuel down the throat and it still wouldn't start right away. I prepared to set up the kicker motor and sat for a few minutes. Turned it over and it fired right up. Ran it for 20 minutes to the dock with no issues. Anyone have an idea? I think it is fuel delivery related. Could have overheated, but highly doubtful. I saw no smoke coming from the engine in any place and when I got it started up again the water temp was right at 140. Could it be something with the red circuit breaker on the fuel filter? (Mounted on engine.) I don't think the fuel is siphoning out of the carb because it started up after being run then sitting, and it died while running. Any ideas? Thanks!
