Fuel Adapter
knouse94
I have been dealing with Merc so I am not sure about what to do with this. The attached picture I assume is my fuel adapter but I am not sure how it works. Thanks
Daviet
Re: Fuel Adapter
Look at the connector on the end of the fuel line, it just snaps on the fitting.
bigdaddy08302
Re: Fuel Adapter
I have the same connection on mine but next to it was a regular barb fitting...is it ok to use that...my hose doesnt have the fitting required to attach...permanent tank under floor and old motor was Force which just connected to the barb.
Daviet
Re: Fuel Adapter
Bigdaddy08302, does your engine have oil injection, a seperate oil tank. You should buy the correct hose end for your fuel line.
bigdaddy08302
Re: Fuel Adapter
nope...no oil injection...what would the difference be if the fuel is getting to the carbs? I guess what I mean is does that connector have a purpose other than a way for the fuel to get to the motor...does it regulate flow or something?
Daviet
Re: Fuel Adapter
It's just a connection, it does not regulate the fuel flow.
F_R
Re: Fuel Adapter
Make sure you don't have VRO oil injection. That is what the barb is for.
