Ok guys here's what I'm dealing with. 90 bayliner caprinwith force 90 out board. I put new cables on due to one being broken/ jammed up. I got the shift cable hooked up, but it seems like the throttle cable is to big.. roughly an inch to long. Both the control itself and the out drive are in nutral.. but won't fit, and another concern I have, is once I do get the cable on... how would I adjust them so the rod/linkage behind/under the carbs won't hit, I've noticed the shifter rod has to either be above or below the linkage before the throttle cable will move, so it won't bind up..
please help!! Dose any one have a step by step procedure from start to finish link my chance.. I can't seem to find anything for this force motor I think I'm begging to see why... lol thanks guys
