frustrated johnson owner
Thread starter- Joined
- Jan 23, 2011
- 1
i bought a 86 179 stratos project boat last summer... i have been working on getting it tournament ready all winter.... have done some engine work,, like stator, power packs, also a new lower unit.... have taken it out a couple times to run it and cant get it up on the pad.... engine is a 86 gt 150 johnson.... it has a 22p 14.5 raker prop that came on the boat when i bought it,, it also has a 6 in jack plate.... motor will only turn 4800 at a top speed of about 48mph... the front will not come up on the boat, spray comes off the side of the boat infront of the drivers seat... i have tried the jack plate in several positions and all are about the same out come.. no pad ride at full throttle... and as low as 4200 rpm.... boat also came with a 25p 13.25 shooter 4 blade prop,,, i know nothing about 4 blades,, that i havent tried,,, any one have a suggestion for a prop that will get this boat moving... i figure that the boat shouldnt have any problems doing 60mph if turning the 5500rpms that is recomended...
thanks
thanks
