Front PS pump bracket
alldodge
Installed some new aluminum headers on my 502. The header manifold is slightly wider then the original cast iron and caused an interference with the power steering (PS) pump. Found an extension bracket from IMCO which extended the PS pump up and out about an inch to clear. The front brace bracket (Mercruiser 98644A-1) is now about an inch or so to short. It is a flat bar which I could weld an extension on it but would like to find one which was longer. The manufacture of the PS?Alternator bracket doen't make the other brace. My guess is most folks don't put it brace back on but I'm worried about a stress brake later. Have any ideas?
Re: Front PS pump bracket
Ayuh,... I gotta believe Imco has run accross this before,... Call 'em up, 'n ask 'em what They'd do,....
alldodge
That's what I did (called IMCO) and they said they didn't make one, so that got me scratching my head real good.
Ayuh,... Gotcha,... How 'bout a picture or two,..??
I've welded up a good many over the years in different apps,...
Gettin' the slot right, 'n scope of it is the key...
alldodge
Will get some pics if someone doesn't come up with something. Plan to check my Rinker and see if the brace on it may be longer then the 502, but have to wait a couple of days to get to it.
Ayuh,... Or look on some Hot Rod motor parts sites,.... Ya might find something that'll work,....
Jegs, Summit, APW,..??...
