Four Winns Fling Fuel Issue.
jimsford4ever
I have a 1994 Four Winns Fling with the 115hp turbojet engine. Will not start. Good spark on all four cylinders. Narrowed it down to it not getting fuel. Spray starting fluid in the carburetor and it fires rite up then stops. Yes it has gas in the tank. It has oil in the injector tank. What is the first thing that I should change? Where is the best place to order parts for this boat?
My second question is. Can you use regular 2 cycle oil in this jet boat motor or does it have to be a marine grade? The oil I was going to use says injector safe. Will it harm the motor?
