Ford Thermostat info.
Mark42
If you are interested in changing the thermostat temperature in your Ford vehicle, these part numbers may be helpful. They are for the modular 4.6 v8 engines, but probably fit others as well.<br /><br />Temp. Motorcraft P/N CSD P/N Engineering P/N Start to Open Full Open<br />192° RT-1153 YC2Z-8575-AA YC2E-8575-AB 188-195° 212°<br />185° RT-1147 YC2Z-8575-BA YC2E-8575-BB 181-189° 210°<br />180° RT-1144 XL3Z-8575-AA XL3V-8575-AA 175-182° 202°<br /><br />The engineering part number is stamped on the thermostat flange. <br /><br />Mark.
ED21
Master Chief Petty Officer
Re: Ford Thermostat info.
Which is better for towing?<br />I assume the cooler T-stat. <br />What is best all around for moderate loads on relatively level(not mountains)ground.
NYMINUTE
If your tow vehicle is set up for towing from the manufacturer, the OEM t-stat rating should be the best for towing.
Mark42
The thermostat is more oriented to vehicle emissions than best performance. That's why underhood temps keep climbing over the last 10 years. Most vehicles will benefit from 185 if they ping on premium or mid-grade gas. Also, thermostats do not operate full open all the time. They respond to engine temps. The ones that open sooner do keep the temp down. People I know with regular temp guages in their Fords show lower all around temps, and that translates to longer oil life, coolant life, belt and hose life, a few more HP and a 0.5 MPG increase.<br /><br />Be warned that the 180 may keep the motor cool enough that the computer thinks the car is still warming up and keeps the fuel enrichment on. I have heard his warning but never met/read about anyone that actually experienced it.<br /><br />For the $10 or so bucks it costs to change, it is worth trying it out if you are interested.<br /><br />One more thing. If your temp guage normally fluctuates while operating the vehicle, ex it rises at traffic lights and drops when the fans kick in, then you will see lower temps register if you change the t-stat. If your temp guage rises to the same place and is rock steady the entire time you operate the vehicle, then you will not see the temp drop when the t-stat is changed. That is because the latter guage is not a true temp guage, but a cold/normal/hot indicator that cannot register the 5* change by the new t-stat.<br /><br />I run the 185 in both my Town Car and Mountianeer. Both perform better with the lower temps.
