Ford 302 50 amp wiring
Jakem
One wire to battery and one to wiring harness?...I ask because I have a pic of what looks like one to starter solinoid
Ayuh,.... The battery cable goes to the solenoid, don't it,..??
Jakem
What i meant by 50 amp was the breaker wiring...there's 2 wires...one says batt..and other terminal says aux....
Ayuh,....
Power on one side, load on the other side,....
Jakem
My diagram in manual shows one wire to power side of starter solinoid
dubs283
Ayuh,.... Which would be power supply from the battery, Right,..??
Wow, full circle here
OP: you mention first 50A breaker wiring (which is understood by many here) then mention solenoid (which was referred to from member and is again, understood by many here)
So....which is it? (breaker or solenoid)
