force trim and tilt
rugardave
Hi, I have a 95 force 120 and the first time since last summer, I tried the t & t and it will go up but not down, Does anyone know what I should try before I take to the dealer? From the very highest point it will go down only about 3 or 4 inches and then seems to bind. Should I lube the linkage?
Frank Acampora
Re: force trim and tilt
First check the fluid level. Sometimes if it is too low, the oil will foam and the tilt will appear to jam.
