force shift linkage/rod/shaft/thing instalation
confusedbyforce
i have a force 125 on a 1988 hurricane tri hull boat the watter pump went bad so when i replaced it i thought i would replace all the seals on the lower unit as well all went well untill i tried to put the shift linkage back into the lower unit and according to the manuel there should be some kind of ears for the rocker assembly lookin thing to intermesh with and there are not. did i loose a part somewhere? how should this go back together?
roscoe
Re: force shift linkage/rod/shaft/thing instalation
What manual are you using?
What page is this referenced on?
Frank Acampora
Your little missing part is usually brass but can be steel. It looks like a square U with two ears on either side. It is most likely called a yoke. It might be part #73 in the drawing. Check around, it fits in the groove of the shaft that fits inside the propshaft ( looks like part #25) and during disassembly it usually falls off. If you did not clean the gearcase it may still be in the front behind the outer bearing race. If you find it, during reassembly coat it and the shaft groove with heavy grease. Position the yoke with the opening down. Pull up all the way on the shift rod to move the arms and openings of the rocker all the way forward. Now, with only the forward gear installed on the prop shaft, carefully insert the shaft and gear assembly into the housing and into the shift rocker. If you are not careful the yoke will miss and /or fall off the shaft. Assuming it didn't, now work the shift rod while holding the prop shaft from moving The dog clutch (part #27) should move forward and backward. If it does not you have missed. Try again. After you have reassembled the gearcase, check again before filling with oil and installing on engine
roscoe
Yes, part 73 is the yoke, Mercury part number F90619-2
If you can't find it, you can still get it from a Mercury dealer for $14.
Good instructions Frank.
