fishthebay
Thread starter- Joined
- Aug 17, 2001
- 180
Knock on wood... This is the first Force problem I have had thus far in my 5 years of running this 1987 85HP motor.<br /><br />This is the problem.<br /><br />I keep my boat in a slip for 2 weeks at a time to fish for Rockfish in the Chesapeake Bay. I usually take the boat out about twice a week.<br /><br />The last few times I have taken it out the motor seems to bog down for a bit and then breaks free.<br /><br />When I go and start the motor, it turns over fine. Before taking off (After its warmed up) I notice the idile is low. When I make it to the end of the no wake zone I give it gas.<br /><br />It doesn't want to move out of the hole at all. I then back off the throttle and try it again. On about the 4th time it breaks free and runs great and fast all night.<br /><br />Yesterday I went down to the slip and pulled the plugs looking for excessive carbon buildup. All 3 look normal. I unscrewed the fuel filter to inspect any debris in the screen and none.<br /><br />The primer bulb is tight and not losing pressure.<br /><br />Any Ideas on what this could be???? I don't want to mess with the carbs, because everything I have read says they shouldn't need any adjustment. Plus I am not a mechanic and don't want to screw anything up.<br /><br /><br />Comments appreciated....<br /><br />Thanks
