Bigprairie1
Thread starter- Joined
- Jun 13, 2007
- 2,568
Ok here area few good questions for the mechanical ones out there:
What affect (if any) on the compression readings will a cold engine test vs. a warm engine test yield?
What affect (if any) on the compression readings will not having the throttle fully opened have?
As you can probably tell....I did my compression test...it went pretty good however I didn't do either of these things for it.
The motor runs really nicely...no problems so far. The readings I got under cold/closed throttle conditions were:
top: 117-118 psi / middle: 126 psi / bottom: 127 psi
Basically the 'math' shows a total % difference there of within 10%...so all good on that front. The motor has about 250-300 hours on it (well maintained) so I would expect it to have some reduction in compression from new.
Still....let me know your thoughts on the results vs the conditions.
Many Thanks.
Many Thanks.
