Force 90 Carb Swap
bojango541
Hello,
I am looking to install a set of carbs from a 1990 90 HP Force onto a 1997 90 HP Force. Will they swap over okay? Thanks
MickLovin
Master Chief Petty Officer
Re: Force 90 Carb Swap
I had a look at the two models carbies, and one has a choke (1990) and one doesn't (1997) so I would say probably not, but you could interchange some parts one to the other, do you have a problem with your 97 carbies?
bojango541
the 1990 actually does have the enricher valve just like the 1997. Are the carbs themselves the same? I'm 95% sure they are
MickLovin
Well one has the front butterfly for the choke and one doesn't, but they still may fit in, just wondering why you would want to.
MickLovin
As I am unsure of what your model numbers are this is waht I found off iboats parts catalog
That's from a 90hp 1990 no particular model number,
That's from a 90hp 1997
MickLovin
So from those pictures, the only difference I see is the butterfly which you won't need by the looks of the parts list.
MickLovin
sorry dunno why it came up twice.
jerryjerry05
What's wrong with the ones you have?
99% of the time the carbs just need a good cleaning and replacing isin't needed.
If he has the enricher his carbs probably don't have the choke butterfly.
bojango541
I actually have a motor with a blown powerhead so I was parting out whats left of it. I have someone that was interested in the carbs and was wondering if they will work for him
bojango541
Thanks for replies, anyone know for sure if they will swap over?
jerryjerry05
If they bolt up, they'd probably work.
They made a TON of different carbs for these motors.
Just make sure the bore on the carb is the same as the intake.
