Force 50HP, Please help
86jac
I purchased the boat this year, the engine was overhauled last year, about 1000.00 put into the engine, I have Force 50HP motor just started today after running for 2 to 3 minutes a loud buzzing sounds comes from the dash. Is this caused by the water pump? Is it over heating? Also I noticed on the lower unit, where 4 bolts mount the lower unit there is a hole near the front right bolt about the size of 22 gauge wire. Is this normal? Thanks for the help.
Here is a picture of the hole,
http://picasaweb.google.com/camper40...67883315990498
Also if someone know of a good O/B mechanic near Baltimore, please let me know, thanks again
James
djsforce
Re: Force 50HP, Please help
I've never heard the buzzing sound myself, but the more recent Forces have an alarm when they are getting too hot. It's a big benefit, as I had an old Chrysler with no alarm, it overheated and never ran well again. The impeller replacement isn't too difficult, search the forum for directions. It can be done by yourself if you have a little technical experience. I have done it.
You mentioned spending some money on this motor already, if the impeller was already changed then it is more complicated, could be the thermostat isn't opening or you have blockage with the water system. Good Luck
86jac
Thanks for the help, yes it was an Alarm for over heating, I talked with a Marine Mechanic, he will coming by this week to replace the thermostat, water pump, and check the engine. again thanks for the help.
James
puddle jumper
You may check out the add a tell tail thread in the force forum. Its easy to do and tells you a lot. Check it out.
