bama.hunter
Thread starter- Joined
- May 23, 2011
- 18
When I got the motor it would run but not idle or cool(no water out of the exhaust).
I've since got it to idle and added a tell-tale to let me know it is peeing/cooling. However when it's running at idle it won't pee, but if I give it a little throttle it will pee out the exhaust great and the tell-tale looks like a water faucet.
It has a brand new water pump, but I did have to use the old shaft seal due to the new one I order not fitting in the new water pump I bought. It could probably still use a new water pump plate, but it's not in bad enough shape that it would harm the impeller.
Any ideas or help would be much appreciated. I've yet to get the boat on the water due to the motor issues.
-Jay
-Jay
