coolguy147
Thread starter- Joined
- Jul 14, 2008
- 2,817
sheesh this has been going on for a very long time. my motor is really hard to start even when its 85 degress out side. take me maybe 25 pulls or more. i think my motor might be flooding some how but im not sure. ive cleaned the carb a lot before. got a fuel filter in. adjusted the carb. last time i ran it i didnt run the high speed needle all the way where it should be and i gained some 1-2 mphs from just makeing it a little bit leaner. i noticed that after i kept lean sneezing at idle. so i said i will ahve to adjust the idle again. i have it at 1 1/2 out. when i do get the motor started after i clean the plugs a bit which r wet i guess cause i can put them on my hands and press then i see a oil out line and gas. but after i clena them i choke the motor it starts in 2 pulls. whats wrong? i cant think of it? air leak aming hard start? ya and by the way i think the lean sneezing stops at idle when i run the motor at full throttle maybe 1/2 -3/4 a bit? but this shows its a dirty carb? checked spark again i got nice even blue white spark and its alternating good not mis fire.
only thought for the hard start is i ahve a problem with my choke. i have to use a cloths pin to keep it closed. and it opens just a little before i noticed when i start it. but today after each time i pulled it i made sure the choke was closed all the way. and still nothing. i reach wide open easily.
what u guys think?
what u guys think?
