SkiDad
- Jul 18, 2010
- 1,518
I picked up a 15 pitch Michigan stainless prop the other day for pretty cheap. Been looking for a long time - hard to find that pitch. Didn't give them too much b/c i couldn't test it for spun hub, etc. I haven't tested it yet b/c the thrust washer doesn't hit flush with the back of the hub. It hits on the brass spline piece and there is a 1/8 - 3/16" gap between the hub and washer. Wasn't sure if that would hurt anything. Do I need a different thrust washer ?
And will i need a few washers in the front of the nut or some other kind of spacer ? The black flare piece I use on my other prop doesn't fit that deep.
1st pic i my aluminium prop that I bought last year... thrust washer works fine. The others are the stainless prop and thrust washer.
PS - any issues running a stainless on force - this prop is DANG HEAVY.
