force 125 rod bearings
89capriforce
does anyone know where i can buy some new rod bearings with cage for a 89 force 125?
Frank Acampora
Re: force 125 rod bearings
Why do you need new big end rod bearings? If you lost them or simply don't trust the originals, then OK. If the original rollers are damaged it is a reasonable bet that the crankpin(s) and rod(s) are damaged too. If that is the case, the new bearings will have a shortened service life.
89capriforce
the old ones are damaged but doesn't look like it did much damage to the crank or rod.
