force 125 impeller woes
yohimbo
Avast!!I have a 1988 Force 125 on a 19 foot flats boat I bought two weeks ago.I did the usual changing of the L/U oil and pulled the impeller also.It was cavitated pretty badly and I was happy to see a much better water circulation when we buttoned it back up and put ears on it.The next day though I went to warm it up and it wouldn't pump a drop of water.When we pulled the L/U again the impeller had been torn to shreds.Turns out they had given me an impeller for a newer model(post Mercruiser buy-out)125 and the doggone thing was 2000's of an inch larger in the shaft sleeve than the other one.We miked it out at the parts store today.It was such a hair different that we really didn't remark on it in the heat of the first job,and at the parts store I had peeked at the catalog and there was nothing else on the page that remotely resembled the part I needed bedsides the one I got.What a major pain in the butt!Why in the heck would they have made something so darn close but of course a mile away in machine spec terms?Beats me how it worked one day and went to the ****ens the next day. Hope I didn't burn the damn thing up while I was staring at it waiting for the water to start pumping out(like it had done so well just the day before).The heat alarm went off and I did shut it down right away.Hope thats not too late.Anyway... you old salts have any comments I would love to hear'em,and anyone new to the game beware of this little detail.If that impeller ain't working your whole mess is shot.I'm at yohimbo@juno.com if anyone wants to write and swap boat stories.
Yepblaze
Re: force 125 impeller woes
I bet if you would not have lost "the key" and replaced it along with the new impeller the thing would have been fine.<br /><br />Just a guess. <br /><br />It sure sounds like you'd want a couple a thou. for it to fit easily on the shaft without welding itself to the shaft after awhile.
Walker
I'm not sure I understand what happened with the new impellor. Even if it was a little too big it should not have shredded itself. Sounds like it was run without water.
roscoe
I will not run my Force on muffs anymore. It just won't start pumping. The pump won't suck the water in. The only way for me to get it to pump is to get on my knees and hold both sides of the muffs real tight to the l/u and turn the water hose way up. This seems to force the water thru. I gave up on this method a few years back. I went to the farm store and bought a 100 gallon water tank for under $50.
