force 125 compression specs/ rough idle
findinghomer
well my engine some times idles very roughs and shuts off. i wanted to rule out compression so i ran test. all cylinders were 126-130. however in my clymer manual it says should be 140-160 psi. is this a sign of engine problems?
now on to the rough idle, i believe its a carb problem? bowl is overflowing with fuel after it runs a few minutes, also my spark plugs were fouled wet, and black. it seems im running really rich. will carb rebuild fix this? if so what all should i replace? thanx in advance
jaybirddog11
Re: force 125 compression specs/ rough idle
I have almost the exact same issues and compression, wet fouled plugs and black (1979 100hp chrysler). I have just replaced my fuel pump diaphragm and have not yet tested but I was told that it could be the problem. I believe your compression is fine. It could improve if you do a decarb. I will be doing this next time out. With regards to your carb issues , I would consider replacing the floats, needle and seats and all gaskets and thoroughly clean everything.
findinghomer
awesome , thanx jbird. im goin to get diaphram, and carb parts, but what exactly is decarb? how does it help compression?
ps. i found and ordered , needle, seat, and diaphram, but cannot find the float, the one here doesn list my motor as fitting. its an 89 125 hp. if you or anyone knows where i can find that please let me know, thanx.
findinghomer
ummm quick question, how do you remove the needle? the seat looks to be pressed into the body?
