FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Can you move the starter pinion gear up manually? You should be able to spin it and move up the shaft as it moves. through the helical thread on the drive shaft. Sometimes the spring which pushed is back gets caught thus the gear gets stuck and will not slide up. A light grease will prevent this from happening.
just installed dual batteries do i run the ground wires to both or just one battery. does the engine and fuel pump ground or to the starting battery only?
also running one voltage guage should I connect that to the starting battery
