Hello Im new to boating and purchased a 1988 Bayliner. It has a Force 125 HP Model C motor. My question I hope to get an answer for relates to the forward and reverse does not engage. I can increase the engine but the drive will not engage. I removed the cotter clip and connecting pin from the gear shaft rod and moved it upwards which engaged the drive so I believe the lower gearing works. When I remove the engine cover I can see the two cables which are controlled by the forward/reverse lever, then move some metal rod linkage turning left to right. Where I have a mental block is what/where is the connection from left to right movement transferred to up and down. I did some research online and was able to find some diagrams but nothing showing me how this connects or how to access it. Any helps very welcome. Paul
