Force 120hp Major Overheat
HenHouse
Hello all, 3 weeks ago I bought my first boat with a Force 120hp outboard. I got a smoking deal and purchased it knowing it was overheating. I've done the following to solve it to no avail, and made a dumb mistake. This forum has been invaluable so far, and I appreciate all the help I can get.
Tested on water before anything else with an infrared laser, and the alarm is working properly.
Replaced impeller and housing. Ensured it was installed correctly.
Replaced the thermostat and tested it on the stove. It works correctly.
It still overheated
I thought it could be a blockage. So I did the following
Replaced exhaust cover gaskets and cleared some minor blockages.
Replaced the head gasket and cover. No blockages.
I took it out this morning to test it after replacing the gaskets. I made a dumb mistake and had my infrared laser set to Celsius. I'm not sure how I did not think to check this. The alarm went off, but when using the laser, I thought I was within the proper operating temperature. Tested on the trailer and out on the lake. The engine was on for about 20 minutes, and about 6 minutes were on plane, the rest were at idle. I continuously read the temps throughout this process in Celsius thinking I was okay. I caught my mistake once back on the trailer. The hottest temp readings I got are as follows.
On trailer testing - 132C / 270F
Tested on trailer in reverse - 180C / 356F
Idled from trailer to dock - 113C / 235F
After 1 min plane - 115C / 240F
After 1 min 30 seconds plane - 125C / 257F
After 5 min plane and 1 min idle back at trailer (when I noticed) - 214F
The engine ran well the whole time only thing I noticed was excess smoke.
No clunking or seizing
Since this I've dropped the lower unit, and the impeller is still good. Removed spark plugs, and they seem ok. I'm not sure how to proceed. 365F is insanely hot, and I can't imagine I didn't cause major damage. Should I do a compression test? Take the head back off and inspect?
I think the overheating issue is due to a possible gasket/o-ring failure at the top of the water tube and exhaust jacket. Do I even try and fix the overheating after getting it to these temps?
Another thing to note is it doesn't overheat on muffs but on the lake, it does.
Please help.
jerryjerry05
More info? year?? Pic of the pump, housing?
IF??? the boat had set for a long time? the insects get up in the holes and make nests for their new young. Usually this gets blown out when the waters put to the motor, but in severe cases it won't.
Snake camera: drop the lower unit and see if the water tube is in the right place?
While the lower unit is off: hook a water hose to the water pipe and run it and see if it still gets hot, if so then there's a blockage in the bottom odf the block, Good luck.
HenHouse
Not sure on the exact year and model because the ID placard on the transom bracket is missing. From my own research, I think it's a 1993 or 92. It has power trim not sure if that changes anything. I'll attach pics
Before changing the gaskets, I ran it with a hose hooked up to the water pipe, and it didn't overheat. Water does escape from what I think is the top of the water pipe as soon as I push water up the pipe. There is a small gap where I can see the tube through the exhaust side. When water is pushed up, I can see it splashing around and coming down. I think the reason it doesn't overheat on muffs/the hose is because it provides more pressure and overcomes the leak. Additionally, I suspect that I may have an exhaust leak that is entering the cooling system.
I did a compression test this morning and got these numbers. Not sure about the reliability of my tester, as it is a cheap one from Harbor Freight.
1 - 138psi
2 - 139psi
3 - 135psi
4 - 132psi
I think that is a good test and indicates I didn't cause major damage with the overheat.
As far as I know, the boat didn't sit for a long time, but I can't confirm that. There is a possibility it sat for a season or two because there were leaves in the hull.
I'll also try and get a snake camera as I don't have one.
Jeff J
I would check the timing too. Not familiar enough with 2-stroke to know how much difference it can make but ignition timing can affect engine temperature.
HenHouse
Attached is a video to demonstrate the leakage found at the top of the water tube when I attach a hose. Not sure if this is normal or not. Hope this helps with what I'm trying to describe.
jerryjerry05
Could be as early as 93 but looks newer 94+ Under the packs and coils on the block is a foundry stamp, the center of the stamp is the year it was cast, also under the bottom carb might be another foundry stamp.
I'd bet if you get a snake camera and run it up along the water tube you'd find the grommet missing or misplaced.
Too much water coming down when the hose is hooked to the pipe.
#17-18
HenHouse
I looked for a foundry stamp under the packs and coils and could not find one. Did spot one under the bottom carb with the numbers 900-817609C and BMP - AE, with the AE being in the middle of the stamp. I also found a number under the flywheel to the right of the packs 800-818154-C1 and another to the left of cylinder 4 on the exhaust K981027.
Not sure how to decode this.
How do I replace the grommet? I can't find any info on how to do it. I want to avoid taking the powerhead off, but from what I can tell, that's required.
Thanks for the help.
HenHouse
I found a stamp with a number above the bottom carb and below the starter solenoid, it reads 90. Attached is a photo of the starter and the stamp I mentioned. I would like to purchase a shop manual to help me, but I'm unsure which to get. The seller told me the engine was a 1992. IMG_3303.jpegIMG_3305.jpeg
I don't think it's a 1995 because the driveshaft housing diagram on marine engine doesn't look like mine.
tg3690
If that's the original powerhead, then you got a 1990 model motor. Parts diagram for 1990 model shows a rubber grommet AND a rubber seal at the top of the copper water line. I don't believe they can be replaced without removing the PH.....but if there is blockage in the bottom of the block then the PH would need to be pulled anyway to deal with that.
You could look on ebay for a service manual.
jerryjerry05
Yup 1992 The stamp under the carb?? it isn't the best indicator, the best is the tag you posted and second would be the block.
The tag says 1208F92C The c indicates a later run model.
They A model used the Prestolite ignition. The C model was when they went to Mercury Ignition. The flywheel shows it's Mercury.
HenHouse
First off, thanks for the responses and help so far.
Not sure what happened to the original ID tag. It looks like it fell off, but I'm unsure. The guy I purchased it from didn't seem to know a lot about boats; granted, neither did I three weeks ago.
I am mechanically inclined, but don't have experience taking engines down to that level. How difficult is it to remove the power head? Does anyone know if it's 100% necessary to service the water line? What's the parts list look like for a project like this, other than the grommet and rubber seal for the water line?
It looks like I'm going to buy a 1992 service manual off eBay. Not confident that it's only a 92, I get the feeling it's multiple years put together. Does anyone know the part n/o for the manual?
Nordin
Not really hard to pull the power head off from the mid leg.
12 screws to remove the mid leg cover, 6 at the back and 6 in the bottom of the cowl.
Then you can remove the nuts that hold the power head to the mid leg it is 10 of them.
Disconnect all wires from the harness to the power head, the remote cables and at last the shift rod coupling under the bottom carb.
Then you should be able to lift the power head from the mid leg.
Maybe you have to wiggle the power head and pry with a bar to release the head from mid leg.
The gasket between the adapter plate and mid leg if there is one maybe "glue" the head to the mid leg.
When power head off you should see the water tube outlet from the water pump.
Look at jerryjerrys attached diagram.
jerryjerry05
Bunch of 92 manuals on ebay.
"120 Force outboard manual 1992"
I put that in the search header and a bunch showed up.
Lots of changes from 91 to 92 and 93 on lots of different stuff .
HenHouse
Update
Finally got around and took the power head off this morning. Have the manual, gasket, and seals.
After pulling the head and being able to inspect the top of the water line, the seal seems to be in perfect condition. I’ll attach pictures. I also removed the spacer and there’s no blockages under the engine.
I haven’t put it back together yet, but there’s nothing obvious that has been causing my overheat. I’m racking my mind and can’t figure it out.
jerryjerry05
It's gonna be a pain but pre mounting to see if the gasket/rubber seal fits right might show the problem??
HenHouse
I pre-mounted it and used some grease around the top of the water line to indicate if it was sealing in the proper place. The grease made a perfect circle around the inlet hole. Also, with the new seal installed, it seemed to hold the plate off a little bit, so maybe the old one was just worn out. I put it all back together and plan on testing it at the lake this evening. I have to wait for the RTV to set. I'll keep y'all updated.
HenHouse
I took it to the lake this evening to test, and it still overheated. The alarm sounded, and the temp never dropped on my infrared thermometer. I am completely baffled as to what the problem could be. I've been through the entire cooling system. I attached a video that shows the exhaust relief ports, as well as one where I ran it without the plug at the top of the thermostat. The hottest temp I got was 202°F at the top of the head.
All suggestions and help is very appreciated.
Nordin
This is some long shot. Do not have a good clue but do you have the right impeller in it.
It should be MTM89984 not MTM-3065 or 3056.
From my experience it should spit more water out of the relief holes at the back when it idles.
Looking at you first pic and I do not see the two small screws for the impeller housing at the front and back of the housing.
If you run it with out the thermostat and thermostat cover does it come water out of the power head where the thermostat should be mounted?
It sounds like you have a blockage in the water jackets somewhere.
Have you tried running water from a garden hose through the engine and look if it come through the thermostat housing?
Try to use compressed air to run through it?
Just some thoughts.
jerryjerry05
Drop the lower, hook a hose to the pickup tube. Start it and check the results.
Gets hot then?? Your exhaust passages might be clogged??
The relief ports look like the motors getting plenty of water.
