jburdadams
Thread starter- Joined
- May 27, 2013
- 41
greetings! you all helped me back in June, so I'm back with another education opportunity. Last time, it would run wide open but wouldn't idle. Different problem this time, that seems related to 'flooding' :
the old 1999 120 Force will idle slowly indefinitely, but will choke down once you advance the throttle or try and put it in gear. Ran fine last weekend, and is full of new gas. Did all the suggestions you all provided back in June: new plugs, checked and tightened all hose clamps, fuel pump, in line filter, float bowl gaskets, idle mixture screws are adjusted per the manual (not touching those again, believe me), adjusted carb linkages, etc, no air leaks. Bulb gets nice and tight, but obviously, too much fuel even though i'm giving it minimal choke. i might add that the excess fuel looks milky blue-white, which is a new one on me.
thanks in advance for your help!
