Force 120 starter, 1995
rugardave
Hi, Guys.
Last time out the starter wouldn't engage the flywheel. Is there anything that I can do to lube or loosen the shaft? Or is the starter shot? Once I pried a wrench under the collar it fired right up. Is this a prelude to something more perminent happening? What should I look at first? Or should I just change the whole thing all together? It spins, but would not rise up meet the flywheel. The battery has plenty of juice.
Thanks
Rugardave
chitownborn
Re: Force 120 starter, 1995
yep wd40 worked for me also, give the bendix a shot of wd
