Re: Foam in battery compartment?
I would secure each battery with a
hold down tray.
If there isn't room for the trays, I would strap each battery so they don't move around. It sounds like you have a 1/2" bottom in that compartment, so I would cut slots in the bottom to run the straps through,,, and around each battery. Then you don't have to worry about screws pulling out of the wood. Several heavy duty ratchet straps would work well.
