Fly wheel nut
PocketRocket8541
Hey all,
Took my fly wheel off (which was a huge pain) ,cleaned underneath it and tried to thread the nut back back on. The nut seems extremely tight; Is this normal? Should I get a new nut or try to use the existing?
Also, I'm still trying to troubleshoot a no spark at the spark plugs issue. Cleaned off the contacts with alcohol and scratch pad...is there anything else I should do?
Thanks
70 hp Johnson
Daviet
Re: Fly wheel nut
The flywheel nut should thread on easily, I would try a new one.
You can go to the CDI website and look up your engine and use their troubleshooting guide to help you find your problem.
