Flushing
Drew72
Whats the easiest way to Flush My 1980s 25hp Evinrude preferably with a hose. looks just like This
oldboat1
set of muffs (a "flusher") is probably the easiest way, initially at least. May have to cut them to fit. OMC used to make a clamp on flusher too (clamped to the anti ventilation plate), but maybe just for smaller models.
I like to use a barrel -- big heavy duty trash can works, with leg sunk deep. Leave the hose running to refresh. In either case (muffs or barrel), don't rev the engine. Just let it idle for a while to clear water passages. Monitor temp (may be due for an impeller).
flyingscott
You need a barrel for it easiest way by far. Muffs generally don't work on them because of the shape of the intake. The intake is in the second pic just make sure you have enough water to cover the waterpump itself.
flyingscott
That is a good option I haven't seen one in a long time but if you can make it it will work should be good. If you don't have a barrel you can try a wet dry vac bottom the 16 gallon ones will usually hold just enough water to work. Take the prop off though I won't tell you how i know they can cut through them.
hardwater fisherman
I mostly use a barrel but I also have removed the bypass cover shown in your first photo and used the muffs.
oldboat1
Yeah, pretty sure I've done that too -- just not sure it's recommended. Probably best to remove the cover plate, I think, but a flusher should get enough water in to operate fine (and flush the system) -- intended as an intake for reverse operation. Want to hold down the hose pressure if you use a flusher of any kind -- just enough pressure so the water sprays out around the fitting.
But in any case would still recommend a barrel. You want water depth up above the impeller -- best about half way up the leg or so. And keep the water fresh (leave the hose on). Slow. Just keep it slow. Don't go by the typical YouTube pics.
hardwater fisherman
Yes if I am just flushing then I use the muffs. But for testing the water pump or just to see if it starts and will idle I like to run it in a barrel. My 40hp will start and idle on one cylinder when run on muffs. I learned that it always starts and idles well in the driveway when run on the muffs. Not always the case when I get to the lake.
frustratedboater
I am sure that is the original design, however is there any chance you can unscrew the plate and flip it? I say that because the position of the holes looks like there would not be much room for the muffs. If it was mine I'd alter the holes, or take a drill and 'increase' them... Any thoughts? Am I way off by saying that?
oldboat1
position at the anti ventilation plate is the problem for muffs -- but can cut the bottom off the rubber cups (recall that fits). I'm not sure the rectangular muffs would fit any better, and the kind that directs water to both sides is unnecessary. The inlet is only on the port side, so that would be where you would position the hose inlet side of the muffs. As I recall, it worked OK (removed the plate to provide as much water as possible). Models may differ, but on the '57s, water under the plate moves downward fore and aft. It's not exactly an open cavity under the plate, but as there is no screen, there is good flow.
[The cover plates on my '57 5 1/2 and 7 1/2s have small scoops facing backwards (toward the transom) to draw water while in reverse. My 10 doesn't have that type of plate, but maybe isn't original. I don't know if the scoops really make much difference in operation (or whether there are additional ports in the cover plates where the little scoops are used -- might be.) And in operation, you are presumably moving slowly in reverse. But all that's beside the point, I guess.]
Anyway.....still better IMO to dunk them for a number of reasons. (I think that's true with more modern motors too, though.)
Drew72
I use this boat for fishing usually a couple of times a month. Its a long day by the time i get the boat back out and a 2 hour tow home. i was hoping i could use a hose and muffs at the slip way but i think i'm going to have a bin ready filled at home where i park it and flush it that way. How long should i leave it running and do i have to do it every time. (my neighbours will love me)
oldboat1
will assume you are a salt water boater. Choose the method that best fits your routine. If it were me, I would rinse the whole rig off if you have a hose at the slip or launch area, then flush it at home -- unless you neighbors aren't going to speak to you because of some noise or runoff. Get a sturdy trash can that fits, and keep the hose running. Let it idle for 10 or 15 minutes -- enough time for it to get up to temp for a bit. Good time to lube linkages too.
Drew72
I've been using it for getting on for ten years but always in fresh water, now im going to start fishing the Thames estuary. i tested flushing with a tank this afternoon, worked a treat. Untitled-1.jpg
Drew72
Drew72
Whats The Linkage and do you have any other tips for salt water proofing.
flyingscott
If you are doing salt water definitely get a tank that way you can mix salt away or something similar in it. That stuff is much more effective as a preventive measure than it is as a fix if you let the salt effects get to far. I think he is talking about all the linkages throttle and shifting. Also I would add a zinc anode to the motor I would just buy the one for a later model 15 hp as it bolts to the cavitation plate
oldboat1
Linkage is pretty much anything that moves and you want to keep moving. Pull the hood off now and then and spray with WD40 or similar (electrical cleaner where appropriate). Also items like the steering ram (grease)** and the ends of control cables**. Salinity varies, and I don't know what you will find. Here in the States, I was a little familiar with Elliot Bay (Seattle) and the upper part of the Chesapeake around Annapolis -- lower salinity in the upper bay/rivers (brackish).
Think your flushing rig looks good, and should work fine. All this talk about flushing can be a little obsessive -- have a beautiful boating area. Salt corrosion is an issue, but it is what it is. (Zincs can help, as indicated -- can't hurt. They bolt up under the anti ventilation plate.) All good....
ed. **if remote steering/controls. but looks like you are running with tiller steering.
flyingscott
One other thing if you don't have a stainless cotter pin in for the propeller nut now is the time to do it. The zinc bolts to the top of the cavitation plate don't put anything down by the propeller.
oldboat1
your call on zincs, Drew. Lot's of discussion and background.
[Edit. The OMC anode kit referenced above is 0173029, available here at iBoats, sourced by Crowley:
"All outboards, mounts under anti-ventilation plate" -- zinc (rather than aluminum or magnesium), as is usually used for salt water boating. The kit is really just the anode with mounting screws and lock washers.
It's a little bit of overkill to put a zinc on a trailered boat, IMO, but on the other hand it's easy and cheap (most types, anyway). You could always put one on and check it during the season to see if there is anything going on.]
Drew72
Thanks oldboat1 and flyingscott. Im going to take advice from both of you, cotter pin and anode. Ive kept this outboard working doing all repairs. i only go slow and only a few miles in fresh water, now its going to work a lot harder going much faster and for longer distances. i feel confident all will be fine now.
