imported_Paul_B
- Apr 29, 2004
- 3
I pulled an old rotten plywood floor out of my 16' alumimum boat. I'm intending to just lay some pieces of pink closed-cell sheet foam in the bottom, under the new floor. I read in a different post that if moisture is trapped against aluminum it can cause oxidation. I'm planning on running pieces of the foam along the keel (perpendicular to the ribs) to allow for drainage. The drainage isn't great any way, so this seemed the best way to keep things drier. Any suggestions? In a related question, I was planning on using one of the bed-liner type products espoused in several other posts to cover the new floor and side walls of the boat. Can I just treat the plywood with something like fiberglass resin before hand, so the bottom won't rot?
