Flooding Force
rockhound
My newly purchased 1994 Force 120 hp. outboard seems floods really easy when starting cold. Never had this problem with my 1986 85 hp. Force. Any suggestions?
Xandre
Re: Flooding Force
Could be a problem with your float.
Your issue is a bit different but I'm having trouble with flooding when I cut out and based off all of the advice I have received from this forum it comes down to the a stuck float or clogged orifice.
Xandre
Re: Flooding Force
BTW-You should post this in the outboard repair area for a better response from others.
QC
Re: Flooding Force
I moved this to the Force OB section. You'll get more focused responses here. Good luck!
