Jasonpastorj
- Aug 31, 2013
- 9
I know the float is supposed to be set at 11/64th drill bit ... I don't see a tab to adjust the hight tho. Any suggestions. Will buy a new one if need be but this one is in good shape.
Look between the ears on the float that the hinge pin goes thru; There's a tab on the float that bears on the needle to shove it up into the hole when the float comes up. You bend that tab up or down to change the float height.
